I have just started using the SMC02B controller with my PIC system.
I’m using a 16F877 in the bootloader mode.
I have a problem with the Change config command.
I send " Serout port d.0,84,[128,2,68] " Acording to the manual (P7) I should see an LED attatched to pin
8 flash 5 times. My problem is that it’s the LED on pin 9 flashing. It’s important as I read on P5 that the controller can be damaged if set for single motor mode. What am I doing wrong?
BeezerUK
