Can someone tell me a little more technical data as far as the Serial (USB Dual Port) is concerned for the Mico Maestro? What is the max speed I can send and receive commands? Approximately how long does it take to receive feed back from the Maestro if I request servo position before I can send the command again?
My script is set up in the way that I have 2 sub routines (no main routine) and I call these routines via the 0xa7 0x01 or 0xa7 0x00 commands. Once I send these commands I keep sending 0x90 0x01 after to determine when the servo has stopped.
