Hi everyone,
I have an issue when I was running the make file for the Pololu USB SDK. After running the make file I get the following error:
make: warning: Clock skew detected. Your build may be incomplete.
Also when trying to run the MaestroAdvancedExample executable I get the following from the command line:
linaro@linaro-ubuntu-desktop:~/Downloads/pololu-usb-sdk/Maestro/MaestroAdvancedExample$ ./MaestroAdvancedExample
Stacktrace:
at System.Drawing.Font.CreateFont (string,single,System.Drawing.FontStyle,System.Drawing.GraphicsUnit,byte,bool) <0x0013f>
at System.Drawing.Font..ctor (string,single,System.Drawing.FontStyle,System.Drawing.GraphicsUnit,byte,bool) <0x0007f>
at System.Drawing.Font..ctor (string,single,string) <0x00057>
at (wrapper remoting-invoke-with-check) System.Drawing.Font..ctor (string,single,string) <0xffffffff>
at System.Drawing.SystemFonts.get_DefaultFont () <0x0005b>
at System.Windows.Forms.Theme..ctor () <0x0002b>
at System.Windows.Forms.ThemeWin32Classic..ctor () <0x00013>
at System.Windows.Forms.ThemeVisualStyles..ctor () <0x00013>
at System.Windows.Forms.ThemeEngine..cctor () <0x00063>
at (wrapper runtime-invoke) object.runtime_invoke_void (object,intptr,intptr,intptr) <0xffffffff>
at System.Windows.Forms.X11DesktopColors..cctor () <0x000a7>
at System.Windows.Forms.XplatUIX11..ctor () <0x0014b>
at System.Windows.Forms.XplatUIX11.GetInstance () <0x0004b>
at System.Windows.Forms.XplatUI..cctor () <0x0010b>
at System.Windows.Forms.Application.EnableVisualStyles () <0x0001b>
at Pololu.Usc.MaestroAdvancedExample.Program.Main () <0x0000b>
Native stacktrace:
Debug info from gdb:
Cannot access memory at address 0x616a653c
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
[New Thread 0x42fff460 (LWP 5121)]
[New Thread 0x42660460 (LWP 5120)]
[New Thread 0x40e8b460 (LWP 5119)]
0x400803a0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
Id Target Id Frame
4 Thread 0x40e8b460 (LWP 5119) "cli" 0x40082384 in __libc_do_syscall () from /lib/arm-linux-gnueabihf/libpthread.so.0
3 Thread 0x42660460 (LWP 5120) "dconf worker" 0x40161276 in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
2 Thread 0x42fff460 (LWP 5121) "gdbus" 0x40161276 in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
* 1 Thread 0x4022e000 (LWP 5117) "cli" 0x400803a0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
Thread 4 (Thread 0x40e8b460 (LWP 5119)):
#0 0x40082384 in __libc_do_syscall () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1 0x4007f6da in do_futex_wait () from /lib/arm-linux-gnueabihf/libpthread.so.0
#2 0x4007f756 in sem_wait@@GLIBC_2.4 () from /lib/arm-linux-gnueabihf/libpthread.so.0
#3 0x001155dc in mono_sem_wait ()
#4 0x000a5b10 in ?? ()
#5 0x000a5b10 in ?? ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 3 (Thread 0x42660460 (LWP 5120)):
#0 0x40161276 in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
#1 0x401d21e8 in poll () from /lib/arm-linux-gnueabihf/libc.so.6
#2 0x4041522e in ?? () from /lib/arm-linux-gnueabihf/libglib-2.0.so.0
#3 0x4041522e in ?? () from /lib/arm-linux-gnueabihf/libglib-2.0.so.0
Thread 2 (Thread 0x42fff460 (LWP 5121)):
Thread 1 (Thread 0x4022e000 (LWP 5117)):
#0 0x400803a0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1 0x40080394 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
#2 0xbede9b30 in ?? ()
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Aborted
I also get a similar error when running the Maestro Control Center.
The computer I am running is an ODROID-U2 (Quad core ARM Cortex-A9 MPCore) with Ubuntu 12.11 Linaro. I was wondering if anyone else experienced this or what the fix is. Thanks in advance for all the help.
