Hello, Sergio.
I moved your post to the “Servo controllers and servos” section of the forum since it seems more appropriate.
It looks like you posted the compiled code instead of your raw script; it would not be practical to make changes to the complied code and upload it back to your Maestro. However, you can follow the suggestion I made in this post to make your script wait for a button press before starting. The button will be ignored if it is pressed again while the script is running.
If you try doing that and run into problems, can you post copies of your settings files that contain your updated scripts (instead of the compiled code)? You can save the settings file from each respective Maestro from the “File” drop-down menu of the Maestro Control Center while it is connected.
