Using the maestro mini serial command set, is it possible to send “set speed” and “set acceleration” values to 24 channels, each set of speed and accel. values being different for each of the 24 channels, and then send a “set multiple targets” command covering all 24 channels, and all of them will use their own speed and accel values to make the moves?
We do not a have a command like the “Set Multiple Targets” for setting speed and acceleration; those settings can only be set one channel at a time. Once you set each channel’s settings, that channel will follow those settings when given a command including the “Set Multiple Targets” command.
