i’m new in pololu servo controllers. I don’t understand if a Maestro servo controller could be useful for me. I’m working in an arm building with servos and I would to know if the Maestro servo controller can perform a unique “Group move”. A unique “Group Move” allows any combination of servos to begin and end motion at the same time, even if the servos have to move different distances.
If the answer is negative, how can I perform this using the Maestro functionalities?
Thanks in advance.
Hello!
Unfortunately, the Maestro is not designed to perform group moves. However, you could achieve that effect if you correctly set the speed limit of each servo before commanding the servos to go their next positions. If you are good with C programming another option would be to control the servos with the Baby Orangutan instead, using our Orangutan Servos library.
-Ken
