What resistance does your force sensing resistor vary through? What you would do is connect it as part of a voltage divider circuit. You would need another resistor with a well chosen resistance to be the other resistor of the divider. The top of the voltage divider would be connected to 5V, the bottom would be connected to GND (0V) and the output would be connected to the signal for the servo channel you are using as an input.
