I am having trouble with the setTarget method from the Pololu SDK. I have 360 degree servos. When I use the configuration program that comes with the Maestro I see that the target is set to 1500 and that is neutral for my servos. When I try to use setTarget(0, 1500) in my application, my servos spin at full speed.
The values in the Status tab of the Maestro Control Center are displayed in units of microseconds, but usually whenever you are writing code for the Maestro you need to use the native units of the Maestro which are quarter microseconds. Please try this:
A value of 0 tells the Maestro to stop sending pulses. Non-zero values are pulse widths. Typical allowed pulse widths for servos are 1000-2000us, so the normal range would be 4000-8000.
