maestro 24servo control rate(hz) no aktive. how can i activate this
I want to use 333hz digital control servo
You can change the rate by reducing the “Period (ms)” setting at the bottom of the “Channel Settings” tab, in the “Advanced Pulse Control” box.
Please note that using a higher signal rate limits the minimum and maximum pulse lengths that the servo channels are capable of. You can find more details in the “Maestro Settings Limitations” section of the Maestro user’s guide.
Thank you so much BrandonM.
murat
