Using on the new raspberry-pi, debian Squeeze (r-pi’s distro).
I’ve tried as standard user, as root, with and without the mono prefix to JrkCmd
pi@raspberrypi:/opt/aRail/pololu_usb_sdk/Jrk/JrkCmd$ sudo mono JrkCmd -s
Error: No jrks found.
pi@raspberrypi:/opt/aRail/pololu_usb_sdk/Jrk/JrkCmd$ sudo mono JrkCmd -l
0 Jrks found:
lsmod:
Module Size Used by
binfmt_misc 5128 1
fuse 49036 1
snd_bcm2835 15388 0
snd_pcm 49240 1 snd_bcm2835
snd_seq 35080 0
snd_timer 13560 2 snd_pcm,snd_seq
snd_seq_device 3684 1 snd_seq
snd 31624 5 snd_bcm2835,snd_pcm,snd_seq,snd_timer,snd_seq_device
snd_page_alloc 2660 1 snd_pcm
evdev 6404 1
lsusb:
Bus 001 Device 007: ID 1ffb:00a1
Bus 001 Device 004: ID 08ff:0009 AuthenTec, Inc.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg:
usb 1-1.3: new full speed USB device number 7 using dwc_otg
usb 1-1.3: New USB device found, idVendor=1ffb, idProduct=00a1
usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=4
usb 1-1.3: Product: Pololu Simple Motor Controller 18v7
usb 1-1.3: Manufacturer: Pololu Corporation
usb 1-1.3: SerialNumber: 3800-7206-3055-3932-5558-0343
I did blacklist the cdc_acm kernel module as upon plugging in the jrk I’d get:
cdc_acm 1-1.3:1.0: This device cannot do calls on its own. It is not a modem.
cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
libusb info:
pi@raspberrypi:/opt/aRail/pololu_usb_sdk/Jrk/JrkCmd$ dpkg -l|grep usb
ii libusb-0.1-4 2:0.1.12-16 userspace USB programming library
ii libusb-1.0-0 2:1.0.8-2 userspace USB programming library
ii libusb-1.0-0-dev 2:1.0.8-2 userspace USB programming library development files
ii libusbmuxd1 1.0.4-1 USB multiplexor daemon for iPhone and iPod Touch devices - library
ii usbmuxd 1.0.4-1 USB multiplexor daemon for iPhone and iPod Touch devices
ii usbutils 0.87-5squeeze1 Linux USB utilities
ii xserver-xorg-video-sisusb 1:0.9.3-2 X.Org X server – SiS USB display driver
kernel:
Linux raspberrypi 3.1.9+ #90 Wed Apr 18 18:23:05 BST 2012 armv6l GNU/Linux
mono version: 2.6.7-5
