I have a four-terminal switch where two of them are inputs, the third terminal is output which is determined by the fourth control terminal to select one of the inputs, i.e. if the signal into control terminal is high voltage, the output equal input A, while the signal into the control terminal is low voltage, the output equal input B.
I intend to use Maestro’s two channels as the two inputs of the switch, which corresponding to two position of the servo. In this case, if I can control the timing of the signal into the control terminal of the switch, I can control the timing of positions of the servo.
Is it doable? Thanks!
Mi
