Hi everyone, this is my very first post here and I’m kind of new to electronics so please bear with me I just got my Serial Low Voltage Dual Controller. I have been able to successfully connect it to an Arduino Duemilanove. However I added a I/O expansion shield which has a somewhat different layout. Here’s a “drawing” of my wiring. Is that OK?
The pins of the Pololu Dual Serial Low Voltage Controller are (left to right):
Pin 0 Motor supply
Pin 1 GND
Pin 2 Logic Supply
Pin 3 Serial In
Pin 4 Reset (according to the instructions any digital pin should work I’m assuming that I should connect it to the PWM pin not the 5V or GND)
Pins 5,6,7,8 Motors + and -
And my wiring (Check the All Sizes-> Large):
flickr.com/photos/mpenoushliev/4383036492/
Thank you
