ive spent a good portion of my day mounting and interfacing one of my robots with a recently purchased QTR-8A wich i have reduced to the six sensor version ( arduino only has 6 analog inputs any ways ) and after messing with it for a while ive come across a problem that is driving me nuts. When i run the example code i found in the Arduino Library Reference i can not get any value out of the readline statement. i have it dumping the value of “position” to my Serial port and all i get is 0. i do have the emitters turned on and if i read from each sensor independantly (with out the library… just doing an AnalogRead ) i get correct values ( from 33 to about 800 ) . but when i use the library and the readline statement i get nothing… this is esential for my robot to work… i dont know what im doing wrong… maybe Some one here can help me… ( and yes i am sliding the line under the sensors during the calibration mode )
–Dick
#include <PololuQTRSensors.h>
PololuQTRSensorsAnalog qtr((unsigned char[]) {0, 1, 2, 3, 4, 5}, 6);
digitalWrite(2, HIGH);
// optional: wait for some input from the user, such as a button press
// then start calibration phase and move the sensors over both
// reflectance extremes they will encounter in your application:
Serial.println("calibrating");
delay(25);
int i;
for (i = 0; i < 250; i++) // make the calibration take about 5 seconds
qtr.calibrate();
delay(20);
// optional: signal that the calibration phase is now over and wait for further
// input from the user, such as a button press
Serial.println("done calibrating");
delay(25);
unsigned int sensors[6];
// get calibrated sensor values returned in the sensors array, along with the line position
int position = qtr.readLine(sensors);
Serial.println(position, DEC);
delay(250);
// if all three sensors see very low reflectance, take some appropriate action for this situation
if (sensors[0] > 750 && sensors[1] > 750 && sensors[2] > 750)
// do something. Maybe this means we're at the edge of a course or about to fall off a table,
// in which case, we might want to stop moving, back up, and turn around.
return;
// compute our "error" from the line position. We will make it so that the error is zero when
// the middle sensor is over the line, because this is our goal. Error will range from
// -1000 to +1000. If we have sensor 0 on the left and sensor 2 on the right, a reading of -1000
// means that we see the line on the left and a reading of +1000 means we see the line on
// the right.
// int error = position - 1000;
// int leftMotorSpeed = 100;
// int rightMotorSpeed = 100;
// if (error < -500) // the line is on the left
// leftMotorSpeed = 0; // turn left
//if (error > 500) // the line is on the right
//rightMotorSpeed = 0; // turn right
// set motor speeds using the two motor speed variables above
