I am trying to use 1 channel as an input with a photoresistor to send a signal to move a servo? How do you wire the input (photoresistor) to your micro maestro board?
Hello, Ricardo.
You can probably make a voltage divider between GND and +5 V where one of the resistors is normal and one of them is a photoresistor. You should test the circuit with a multimeter to see if it works before connecting it to the Maestro’s input line.
This link might be useful:
acroname.com/howto/photoresi … istor.html
