HIGH_SPEED with VL53L0X?
I ran across this topic while looking for solutions to my own problem with too-slow measurement responses for a wall-following robot project, and thought my testing results using a 6-element array of VL53L0X sensors might be useful for others.
I combined the code from the above posts with my setup code for multiple sensors, and recorded the distance measurements from all six sensors. The interesting this is the total loop time required to produce measurements for all six sensors was still only about 18-19 mSec. IOW (assuming I’m not blowing smoke here), the additional five sensors don’t impose any significant additional time penalty!
Here’s my code:
    Created:	10/1/2020 3:49:01 PM
    Author:     FRANKNEWXPS15\Frank
    This demo program combines the code from my Teensy_VL53L0X_I2C_Slave_V2
    project with the VL53L0X 'high speed' code from the Pololu support
    forum post at https://forum.pololu.com/t/high-speed-with-vl53l0x/16585/3
    Created:	8/4/2020 7:42:22 PM
    This project merges KurtE's multi-wire capable version of Pololu's VL53L0X library
    with my previous Teensy_VL53L0X_I2C_Slave project, which used the Adafruit VL53L0X
    library.  This (hopefully) will be the version uploaded to the Teensy on the 2nd
    deck of Wall-E2 and which controls the left & right 3-VL53L0X sensor arrays
#include <Wire.h> //using Wire.h here instead of i2c_t3.h for multiple I2C bus access
#include <VL53L0X.h>
#include "I2C_Anything.h" //local version modified to use Wire.h vs SBWire
volatile uint8_t request_type;
enum VL53L0X_REQUEST
  VL53L0X_CENTERS_ONLY,
  VL53L0X_RIGHT,
  VL53L0X_LEFT,
  VL53L0X_BOTH //added 08/05/20
//right side array
VL53L0X lidar_RF(&Wire1);
VL53L0X lidar_RC(&Wire1);
VL53L0X lidar_RR(&Wire1);
//left side array
VL53L0X lidar_LF(&Wire2);
VL53L0X lidar_LC(&Wire2);
VL53L0X lidar_LR(&Wire2);
//XSHUT required for I2C address init
//right side array
const int RF_XSHUT_PIN = 23;
const int RC_XSHUT_PIN = 22;
const int RR_XSHUT_PIN = 21;
//left side array
const int LF_XSHUT_PIN = 5;
const int LC_XSHUT_PIN = 6;
const int LR_XSHUT_PIN = 7;
const int MAX_LIDAR_RANGE_MM = 1000; //make it obvious when nearest object is out of range
//right side array
uint16_t RF_Dist_mm;
uint16_t RC_Dist_mm;
uint16_t RR_Dist_mm;
//left side array
uint16_t LF_Dist_mm;
uint16_t LC_Dist_mm;
uint16_t LR_Dist_mm;
float RightSteeringVal;
float LeftSteeringVal;
const int SLAVE_ADDRESS = 0x20; //just a guess for now
const int DEFAULT_VL53L0X_ADDR = 0x29;
  Serial.begin(115200);
  Wire.begin(SLAVE_ADDRESS); //set Teensy Wire0 port up as slave
  Wire.onRequest(requestEvent);  //ISR for I2C requests from master (Mega 2560)
  Wire.onReceive(receiveEvent); //ISR for I2C data from master (Mega 2560)
  Wire1.begin();
  Wire2.begin();
  // wait until serial port opens ... For 5 seconds max
  while (!Serial && millis() < 5000);
  pinMode(RF_XSHUT_PIN, OUTPUT);
  pinMode(RC_XSHUT_PIN, OUTPUT);
  pinMode(RR_XSHUT_PIN, OUTPUT);
  pinMode(LF_XSHUT_PIN, OUTPUT);
  pinMode(LC_XSHUT_PIN, OUTPUT);
  pinMode(LR_XSHUT_PIN, OUTPUT);
  //Put all sensors in reset mode by pulling XSHUT low
  digitalWrite(RF_XSHUT_PIN, LOW);
  digitalWrite(RC_XSHUT_PIN, LOW);
  digitalWrite(RR_XSHUT_PIN, LOW);
  digitalWrite(LF_XSHUT_PIN, LOW);
  digitalWrite(LC_XSHUT_PIN, LOW);
  digitalWrite(LR_XSHUT_PIN, LOW);
  //now bring lidar_RF only out of reset and set it's address
  //input w/o pullups sets line to high impedance so XSHUT pullup to 3.3V takes over
  pinMode(RF_XSHUT_PIN, INPUT);
  delay(10);
  if (!lidar_RF.init())
    Serial.println("Failed to detect and initialize lidar_RF!");
    while (1) {}
  //from Pololu forum post
  lidar_RF.setMeasurementTimingBudget(20000);
  lidar_RF.startContinuous();
  lidar_RF.setAddress(DEFAULT_VL53L0X_ADDR + 1);
  Serial.printf("lidar_RF address is 0x%x\n", lidar_RF.getAddress());
  //now bring lidar_RC only out of reset, initialize it, and set its address
  pinMode(RC_XSHUT_PIN, INPUT);
  delay(10);
  if (!lidar_RC.init())
    Serial.println("Failed to detect and initialize lidar_RC!");
    while (1) {}
  lidar_RC.setMeasurementTimingBudget(20000);
  lidar_RC.startContinuous();
  lidar_RC.setAddress(DEFAULT_VL53L0X_ADDR + 2);
  Serial.printf("lidar_RC address is 0x%x\n", lidar_RC.getAddress());
  //now bring lidar_RR only out of reset, initialize it, and set its address
  pinMode(RR_XSHUT_PIN, INPUT);
  delay(10);
  if (!lidar_RR.init())
    Serial.println("Failed to detect and initialize lidar_RR!");
    while (1) {}
  lidar_RR.setMeasurementTimingBudget(20000);
  lidar_RR.startContinuous();
  lidar_RR.setAddress(DEFAULT_VL53L0X_ADDR + 3);
  Serial.printf("lidar_RR address is 0x%x\n", lidar_RR.getAddress());
  //now bring lidar_LF only out of reset, initialize it, and set its address
  pinMode(LF_XSHUT_PIN, INPUT);
  delay(10);
  if (!lidar_LF.init())
    Serial.println("Failed to detect and initialize lidar_LF!");
    while (1) {}
  lidar_LF.setMeasurementTimingBudget(20000);
  lidar_LF.startContinuous();
  lidar_LF.setAddress(DEFAULT_VL53L0X_ADDR + 4);
  Serial.printf("lidar_LF address is 0x%x\n", lidar_LF.getAddress());
  //now bring lidar_LC only out of reset, initialize it, and set its address
  pinMode(LC_XSHUT_PIN, INPUT);
  delay(10);
  if (!lidar_LC.init())
    Serial.println("Failed to detect and initialize lidar_LC!");
    while (1) {}
  lidar_LC.setMeasurementTimingBudget(20000);
  lidar_LC.startContinuous();
  lidar_LC.setAddress(DEFAULT_VL53L0X_ADDR + 5);
  Serial.printf("lidar_LC address is 0x%x\n", lidar_LC.getAddress());
  //now bring lidar_LR only out of reset, initialize it, and set its address
  pinMode(LR_XSHUT_PIN, INPUT);
  if (!lidar_LR.init())
    Serial.println("Failed to detect and initialize lidar_LR!");
    while (1) {}
  lidar_LR.setMeasurementTimingBudget(20000);
  lidar_LR.startContinuous();
  lidar_LR.setAddress(DEFAULT_VL53L0X_ADDR + 6);
  Serial.printf("lidar_LR address is 0x%x\n", lidar_LR.getAddress());
  Serial.printf("Msec\tLFront\tLCtr\tLRear\tRFront\tRCtr\tRRear\tLSteer\tRSteer\n");
  RF_Dist_mm = lidar_RF.readRangeContinuousMillimeters();
  RC_Dist_mm = lidar_RC.readRangeContinuousMillimeters();
  RR_Dist_mm = lidar_RR.readRangeContinuousMillimeters();
  RightSteeringVal = (RF_Dist_mm - RR_Dist_mm) / 100.f; //rev 06/21/20 see PPalace post
  LF_Dist_mm = lidar_LF.readRangeContinuousMillimeters();
  LC_Dist_mm = lidar_LC.readRangeContinuousMillimeters();
  LR_Dist_mm = lidar_LR.readRangeContinuousMillimeters();
  LeftSteeringVal = (LF_Dist_mm - LR_Dist_mm) / 100.f; //rev 06/21/20 see PPalace post
  Serial.printf("%lu\t%d\t%d\t%d\t%d\t%d\t%d\t%2.2f\t%2.2f\n",
    millis(),
    LF_Dist_mm, LC_Dist_mm, LR_Dist_mm,
    RF_Dist_mm, RC_Dist_mm, RR_Dist_mm,
    LeftSteeringVal, RightSteeringVal);
and here's the results from the run
Opening port
Port open
lidar_RF address is 0x2a
lidar_RC address is 0x2b
lidar_RR address is 0x2c
lidar_LF address is 0x2d
lidar_LC address is 0x2e
lidar_LR address is 0x2f
Msec	LFront	LCtr	LRear	RFront	RCtr	RRear	LSteer	RSteer
1238	530	488	424	195	271	297	1.06	-1.02
1256	532	516	411	190	261	294	1.21	-1.04
1274	558	525	429	193	249	296	1.29	-1.03
1293	545	526	418	194	254	293	1.27	-0.99
1311	532	516	411	196	270	284	1.21	-0.88
1329	528	516	411	193	274	295	1.17	-1.02
1347	547	515	412	190	259	303	1.35	-1.13
1365	542	503	404	191	261	295	1.38	-1.04
1383	556	536	425	199	250	295	1.31	-0.96
1401	551	536	415	195	247	296	1.36	-1.01
1420	525	516	411	190	265	300	1.14	-1.10
1438	540	530	415	205	257	299	1.25	-0.94
1456	532	508	420	201	280	298	1.12	-0.97
1474	525	521	411	202	246	295	1.14	-0.93
1492	544	529	429	186	247	294	1.15	-1.08
1511	533	528	423	197	260	288	1.10	-0.91
1529	544	522	417	193	251	287	1.27	-0.94
1547	549	530	420	200	271	296	1.29	-0.96
1565	545	496	424	203	261	287	1.21	-0.84
1583	544	504	410	198	269	301	1.34	-1.03
1601	553	537	409	194	262	299	1.44	-1.05
1619	551	522	409	191	264	290	1.42	-0.99
1638	548	537	430	195	256	292	1.18	-0.97
1656	538	505	420	186	252	293	1.18	-1.07
1674	538	516	423	194	265	284	1.15	-0.90
1692	535	529	429	193	258	296	1.06	-1.03
1710	544	514	428	197	260	288	1.16	-0.91
1728	539	528	415	201	270	277	1.24	-0.76
1746	541	519	420	198	248	294	1.21	-0.96
1765	535	522	426	190	265	294	1.09	-1.04
1783	536	521	411	193	254	293	1.25	-1.00
1801	540	522	423	194	265	308	1.17	-1.14
1819	553	540	422	196	263	297	1.31	-1.01
Apparently, I can get results from all six sensors in the same time as for just one sensor. Anyone care to comment - is this too good to be true?
Frank
