Hello nathanb,
thanks for answering!
I also tried the continuous measurement mode in the example. It has no HIGH_SPEED switch, so I inserted setMeasurementTimingBudget() manually. Further more I reduced the sketch to the minimum (no TIMEOUT ckecking, just one println). The code is attached.
/* This example shows how to use continuous mode to take
range measurements with the VL53L0X. It is based on
vl53l0x_ContinuousRanging_Example.c from the VL53L0X API.
The range readings are in units of mm. */
#include <Wire.h>
#include <VL53L0X.h>
VL53L0X sensor;
// Serial.begin(9600);
Serial.begin(115200);
Wire.begin();
sensor.init();
// sensor.setTimeout(500);
// Start continuous back-to-back mode (take readings as
// fast as possible). To use continuous timed mode
// instead, provide a desired inter-measurement period in
// ms (e.g. sensor.startContinuous(100)).
sensor.setMeasurementTimingBudget(20000);
sensor.startContinuous();
// Serial.print(sensor.readRangeContinuousMillimeters());
// if (sensor.timeoutOccurred()) { Serial.print(" TIMEOUT"); }
// Serial.println();
Serial.println(sensor.readRangeContinuousMillimeters());
I get values from Arduino IDE like the following (no 20 ms intervals):
07:24:53.948 -> 52
07:24:53.981 -> 56
07:24:53.981 -> 49
07:24:54.015 -> 49
07:24:54.015 -> 57
07:24:54.048 -> 54
07:24:54.048 -> 53
07:24:54.081 -> 55
07:24:54.114 -> 48
07:24:54.114 -> 51
07:24:54.148 -> 50
07:24:54.148 -> 54
07:24:54.181 -> 54
07:24:54.181 -> 55
07:24:54.214 -> 49
07:24:54.214 -> 50
07:24:54.247 -> 50
07:24:54.281 -> 55
07:24:54.281 -> 49
07:24:54.314 -> 52
07:24:54.314 -> 54
07:24:54.347 -> 48
07:24:54.347 -> 52
07:24:54.380 -> 49
07:24:54.380 -> 51
07:24:54.414 -> 48
07:24:54.447 -> 51
07:24:54.447 -> 48
07:24:54.480 -> 53
07:24:54.480 -> 52
07:24:54.513 -> 56
07:24:54.513 -> 48
It seems to me, that setMeasurementTimingBudget() is not enough to minimize the time for measurement. Has it ever worked at someone?
Reading the datasheet link (thanks!) I’m not sure, if 8 ms is theoretically possible. Maybe the datasheet means:
Initialization (~1ms*) plus
Range set up (~8ms*) plus
Range measurement (~8ms) plus
Digital processing (~0.8ms*)
In sum it is near 20 ms, but maybe I’m wrong with this interpretation. I would be happy, if even 20 ms would be possible. Down to 8 ms would be a dream.
