I recently experimented with the Dual Serial Motor Control PIC driving a discrete MOSFET H Bridge. The H Bridge was made of two IPS0551 and two IPS5551 MOSFET switches. The only other parts used were four 1k ohm resistors, one on each MOSFET input. A BS2 was used to create the Serial Out commands to the PIC. Here is what I found:
The PIC outputs float during the serial communications.
Two pins (13, 14) on my BS2 are burned out.
The PIC doesn’t respond at Baudmode = 32 (19.23 Kb/s), but works flawlessly at Baudmode = 33 (18.87 Kb/s) or Baudmode = 34 (18.52 Kb/s).
Turning the motor on, off or reverse at 12, 24, or 36 volts works great.
I tried the example speed up/speed down/reverse speed up/reverse speed down routine. The motor that I was using is a new, 12 volt DC automotive power window motor with worm drive. The motor “sings” at any speed less than about 80% of max. During the “singing” the MOSFET switches generate a lot of heat.
The thermal shutdown on the MOSFET switches works!!! They reset during the standard PWM “off” states or when the BS2 sending data to the PIC.
The “singing” of the motor is the result of the relatively low PWM frequency of 600 Hz for the PIC.
I tried a smaller motor at 24 volts. The speed up/speed down routine didn’t generate any “singing” but resulted in a very smooth speed transition
Conclusion: smaller motors will work better with the 600 Hz PWM frequency than larger motors.
I tried our big sumo motors (Peg Perego). They “sang” at speeds under 10% of max. Using 12 volt power, the Peg Perego motor drew 2.30 amps and combined high side and low side H Bridge voltage drop was .024 volts. Using 24 volt power, the motor drew 4.00 amps and combined high side and low side H Bridge voltage drop was .044 volts. Using 36 volt power, the motor drew 6.20 amps and there was .070 volts total drop in the H Bridge. This calculates out to about .005 to .006 ohms per MOSFET switch. This correlates nicely with the MOSFET specifications.
Rick Brooks
