I found this code on a website and it seems to work very well. However, it is very similar to something I had written before and I do not really understand why my code doesnt work and this one does. From looking at the code the only difference I can see is the “>>7” and the “& 0x7f”. I dont understand what these mean??? Also, the pololu sets its neutral value after reciveing a value from 500-1500. But i thought that the Serial was only able to transmit a max value of 256?? Im new to electronics so please keep everything simple. Thanks in advance!
pos_hi = temp >> 7; //shift bits 8 thru 13 by 7
pos_low = angle & 0x7f; //get lower 7 bits of position
The entire code is below thanks again.
// Pololu micro serial servo controller modes
// Software Serial from Arduino example by Tom Igoe
// put() (now position_absolute) & set_speed() functions found on pololu forums & modified
/ mike crist 2009-01-03
#include <SoftwareSerial.h>
#define rxPin 2
#define txPin 3
// set up a new serial port
SoftwareSerial softSerial = SoftwareSerial(rxPin, txPin);
void setup()
pinMode(rxPin, INPUT);
digitalWrite(txPin, HIGH); // keeps pololu board from getting spurious signal
pinMode(txPin, OUTPUT);
// set the data rate for the hardware serial port
Serial.begin(9600);
// set the data rate for the SoftwareSerial port
softSerial.begin(9600);
// set initial servo speeds
set_speed(0, 127);
set_speed(1, 10);
set_speed(2, 10);
set_speed(3, 10);
//set and move servos to neutral positions using command 5
set_neutral(0, 5000);
set_neutral(1, 3000);
set_neutral(2, 3000);
set_neutral(3, 3000);
//initialize servos using command 0
set_servo_parameters(0, 15);
set_servo_parameters(1, 15);
set_servo_parameters(2, 15);
set_servo_parameters(3, 15);
set_servo_parameters(4, 15);
void loop()
void set_servo_parameters(byte servo, byte rangeVal)
//this function uses pololu mode command 0 to set servo parameters
//servo is the servo number (typically 0-7)
//rangeVal of 15 gives 180 deg in 8-bit, 90 deg in 7 bit
byte temp;
byte parameters;
temp = 1 << 6; //set first two bits of parameters (on = 1, forward = 0)
temp = temp + (rangeVal & 0x1f); //put first five bits of rangeVal into temp
parameters = temp & 0x7f; //take only bottom 7 bits
//Send a Pololu Protocol command
softSerial.print(0x80,BYTE); //start byte
softSerial.print(0x01,BYTE); //device id
softSerial.print(0x00,BYTE); //command number
softSerial.print(servo,BYTE); //servo number
softSerial.print(parameters,BYTE); //parameters
void set_speed(byte servo, byte speedVal)
//this function uses pololu mode command 1 to set speed
//speedVal is servo speed (1=slowest, 127=fastest, 0=full)
//set speedVal to zero to turn off speed limiting
speedVal = speedVal & 0x7f; //take only lower 7 bits of the speed
softSerial.print(0x01,BYTE); //command number
softSerial.print(speedVal,BYTE); //speed
void position_7bit(byte servo, byte posValue)
//this function uses pololu mode command 2 to set position
//posValue * range (set with command 0) adjusted by neutral (set with command 5)
//determines servo position
byte pos = posValue & 0x7f; //get lower 7 bits of position
softSerial.print(0x02,BYTE); //command number
softSerial.print(pos, BYTE); //position
void position_8bit(byte servo, byte posValue)
//this function uses pololu mode command 3 to set position
byte temp;
byte pos_hi,pos_low;
temp = posValue & 0x80; //get bit 8 of position
pos_hi = temp >> 7; //shift bit 8 by 7
pos_low = posValue & 0x7f; //get lower 7 bits of position
softSerial.print(0x03,BYTE); //command number
softSerial.print(pos_hi, BYTE); //bits 8 thru 13
softSerial.print(pos_low, BYTE); //bottom 7 bits
void position_absolute(byte servo, int angle)
//this function uses pololu mode command 4 to set absolute position
//angle is the absolute position from 500 to 5500
unsigned int temp;
temp = angle & 0x1f80; //get bits 8 thru 13 of position
softSerial.print(0x80, BYTE); //start byte
softSerial.print(0x01, BYTE); //device id
softSerial.print(0x04, BYTE); //command number
softSerial.print(servo, BYTE); //servo number
void set_neutral(byte servo, int angle)
//this function uses pololu mode command 5 to set neutral position
unsigned int temp;
softSerial.print(0x05, BYTE); //command number
