necessary that the robot around in a loop and stop
how do I put a start and stop time after
and how to use the PID? My 3pi this with a good time however I know that could improve
I am using the following program
My LCD does not work will be I did something wrong?
#include <pololu/3pi.h>
#include <avr/pgmspace.h>
#include <pololu/orangutan.h>
#include <pololu/qtr.h>
#include <pololu/encoders.h>
#include <pololu/analog.h>
#include <pololu/buzzer.h>
#include <pololu/time.h>
#include <pololu/motors.h>
#include <pololu/lcd.h>
#include <pololu/leds.h>
#include <pololu/pushbuttons.h>
#include <pololu/serial.h>
const char welcome_line1[] PROGMEM = " Pololu";
const char welcome_line2[] PROGMEM = "3\xf7 Robot";
const char demo_name_line1[] PROGMEM = "Line";
const char demo_name_line2[] PROGMEM = "follower";
const char welcome[] PROGMEM = ">g32>>c32";
const char go[] PROGMEM = "L16 cdegreg4";
const char levels[] PROGMEM = {
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111
void load_custom_characters()
lcd_load_custom_character(levels+0,0);
lcd_load_custom_character(levels+1,1);
lcd_load_custom_character(levels+2,2);
lcd_load_custom_character(levels+3,3);
lcd_load_custom_character(levels+4,4);
lcd_load_custom_character(levels+5,5);
lcd_load_custom_character(levels+6,6);
clear();
void display_readings(const unsigned int *calibrated_values)
unsigned char i;
for(i=0;i<5;i++) {
const char display_characters[10] = {' ',0,0,1,2,3,4,5,6,255};
char c = display_characters[calibrated_values[i]/101];
print_character(c);
int integral;
int last_proportional;
void initialize()
unsigned int counter;
unsigned int sensors[5];
pololu_3pi_init(2000);
load_custom_characters();
print_from_program_space(welcome_line1);
lcd_goto_xy(0,1);
print_from_program_space(welcome_line2);
play_from_program_space(welcome);
delay_ms(1000);
clear();
print_from_program_space(demo_name_line1);
lcd_goto_xy(0,1);
print_from_program_space(demo_name_line2);
delay_ms(1000);
while(!button_is_pressed(BUTTON_B))
int bat = read_battery_millivolts();
clear();
print_long(bat);
print("mV");
lcd_goto_xy(0,1);
print("Press B");
delay_ms(100);
wait_for_button_release(BUTTON_B);
delay_ms(1000);
for(counter=0;counter<80;counter++)
if(counter < 20 || counter >= 60)
set_motors(40,-40);
set_motors(-40,40);
calibrate_line_sensors(IR_EMITTERS_ON);
delay_ms(20);
set_motors(0,0);
unsigned int position = read_line(sensors,IR_EMITTERS_ON);
clear();
print_long(position);
lcd_goto_xy(0,1);
display_readings(sensors);
delay_ms(100);
clear();
print("Go!");
play_from_program_space(go);
while(is_playing());
int main()
initialize();
while(1)
unsigned int position = read_line_white(sensors,IR_EMITTERS_ON);
if(position < 1000)
set_motors(35,155);
left_led(0);
right_led(1);
else if(position < 3000)
set_motors(150,150);
left_led(0);
right_led(0);
set_motors(155,35);
left_led(1);
right_led(0);
