Help: c# Maestro 24 read Analog signal and servo position
Hi.
c# Maestro 24 How to read Analog signal and servo position.
I manage to get controlling the servo target, and change the speed.
I look at some code example and I am not getting it how to read analog signal and servo position.
Now I need to do two more things.
How to read analog signal to channel 0.
How to read servo position to channel 3.
Any help in C# would be great.
Thank in advance.
Hi
I just figure how to do the reading position for the servo.
ServoStatus[] servos;
usc.getVariables(out servos);
        PositionTextBox.Text = servos[0].position.ToString();
Now I just need to read analog input.
Any idea how to do in C#
After you have configured Channel 3 as an input using the Maestro Control Center, then just use this expression in the program above in order to get the input value:
servos[3].position
