I am using a 6 channel servo controller that is pre programmed with a script. It rotates two servos in opposite directions when triggered. I am trying to modify it with the Maestro program and have had success changing the speed. with no modification to the original script, I get about 100 degrees of servo travel. The program shows the low value of 992 and the high value of 2000. If I increase the low value or decrease the high value, I can get less than the 100 degrees on the adjusted end. However, If I decrease the 992 or increase the 2000, there is no change. I still just get the original 100 degrees of travel. I really want to get 180 degrees of travel. I am just wondering if anyone can point me in the right direction to be able to get more movement.
This is my first project and would appreciate any help.
Thanks
Here is the script.
JP Gate Settings V3 05-30-15.txt (2.5 KB)
