Hello all.
which heatsink and fan do you recommend for the jrk12v12? (md03a chip), I need the best cooler system.
Thank you!
Hello all.
Thank you!
We don’t have much experience adding heat sinks to our drivers, and we don’t have anything specific to recommend to you. I think the ultimate solution will depend a lot on your particular installation and power requirements. Obviously, the bigger the heat sink you can fit, the more heat you will be able to dissipate. If you do find a good heat sinking solution, we’d love to hear about it.
- Ben
Thank you for answer Ben.
I am trying to build a DIY heatsink cutting and modifing a “cooler master” cpu heatsink (alluminium) using the fan included.
Not again tested but some other guys already made a similar thing with great results.
I need it 'cause I am using the jrk12v12 with DC 12v 25amps (max) electric winch.My jrk is pretty stressed and In some moments my winch ask more than 12amps so I get my jrk heats.
I can tell you that other guys are using the jrk12v12 as me (pure war for the little card…)and with the DIY heatsink+fan they have all under control
