Halloween help
hello have the code below and wish to just add ch 4 & 5 with leds. I would love for ch4 to stay on thru button presses and ch5 to come on when open and off when closed. is this doable? Would take my halloween to another level thank you for any help. :
goto main_loop
sub button
0 get_position 500 less_than
return
sub wait_for_button_press
wait_for_button_open_10ms
wait_for_button_closed_10ms
return
sub wait_for_button_open_10ms
get_ms
begin
button
if
drop get_ms
else
if drop return endif
endif
repeat
sub wait_for_button_closed_10ms
get_ms
begin
button
if
else
drop get_ms
endif
repeat
main_loop:
begin
2250 9000 frame
9000 2250 frame
repeat
sub frame
1 servo 2 servo
return
Helllo.
If I understand you correctly, you want the following correspondence:
button closed => channel 4 LED on, channel 5 LED off
button open => channel 4 LED off, channel 5 LED on
First of all, you should follow the instructions in the “LED” subsection of the “Attaching Servos and Peripherals” section of the Maestro user’s guide. Then you could probably just modify your “wait_for_button_press” code like this:
  8000 4 servo  # LED4 on
  4000 5 servo  # LED5 off
  4000 4 servo  # LED4 off
  8000 5 servo  # LED5 on
  return
The final step is to take a video of your project in action, and write a tutorial here about how you made it!
