Hi:
I’m new to this forum and am wondering about the limits on the GM10 Pagermotor and gearbox. I have animated a sign which turns 45 degress and back and have modified the stops on the gearbox and also removed the centering spring. My design works best with only .5 volt applied to the motor. The voltage is reversed via a DPDT relay The gearbox is designed apparently to “slip” like a clutch at the higher voltages, but my motor only stalls with the low voltage applied. How long before or will this harms the motor? I have another part of the sign which uses AC or dc power to flash lights. ( the circuit puts out dc power to the led’s.) It turns on via a current sensing “donut” . Would it make sense to purchase a new relay with a current sensing pick-up to turn off the dc power to my little motor when the ac board is off? I really don’t need the GM10 to hold anything via the spring or voltage constantly on. Any help is appreciated. The GM10 really is a nice little set-up.
Thanks,
Mark
