Get variables struct
hello,
I am trying to create a function to get a servo position using c code in linux using usb-lib-1.0
i wanted to ask whether the variable struct that I have created is correct.
struct servoSetting
    unsigned short position;
    unsigned short target;
    unsigned short speed;
    unsigned char acceleration;
struct uscVariables
    // Fix bytecode_asm.asm if you change the order or size of
    // variables in this struct.
    // offset: 0
    unsigned char stackPointer;
    // offset: 1
    unsigned char callStackPointer;
    // offset: 2
     unsigned short errors;
    // offset: 4
     unsigned short programCounter;
    // offset: 6
    short buffer[3]; // protects other RAM from being corrupted by improper instructions
    // offset: 12
    short stack[32];
    // offset: 76
	unsigned short callStack[10];
    // offset: 96
    unsigned char scriptDone; // 1 = done; 2 = about to run a single step then be done - placed here to protect against accidental overwriting of Setting
    // offset: 97
    unsigned char buffer2; // protects other RAM from being corrupted by improper instructions
    // offset: 98
    struct servoSetting servoSetting[6];
Hello, atehleb.
Which model of Pololu servo controller do you have?
I have the 6 channel usb controller
pololu.com/catalog/product/1350
Ok, those structs look good to me, except that by default GCC will add padding to your structs to make the variables be aligned a certain way. You need to tell GCC to NOT add that padding by using the “packed” attribute:
struct __attribute__ ((packed)) servoSetting
struct __attribute__ ((packed)) uscVariables
You said you are in Linux so I assumed you are using GCC, but whatever compiler you are using should have an option for packing structs.
Thanks a lot for your reply.
However I am using g++ and it does not recognize __attribute__ ((packed))
I am assuming using #pragma pack(1)
and #pragma pack()
will work?
thanks
atehleb
Sorry, after some experimentation I have found that the attribute actually needs to go before the struct name. I have updated by previous post, so please try again.
Yup, Thanks a lot for your help.
Also I checked and for g++ using
#pragma pack(1)
struct servoSetting
struct uscVariables
#pragma pack()
is also giving same results
atehleb
