Is there a way to get the min and max values stored for a channel via serial commands?
I have the following problem: I’m using a windows joystick to control a few servos. The servo controller will be installed in the model and the min/max values will be configured via the control center to fit the servos used. But without knowing these values in my program I have no way to make the full swing of the joystick match a full swing of the servos. I really want to avoid to have to read the values from the control center and manually enter them in my program every time I connect different controller (because the model will be used by “normal” users alot and it would be very error prone if they had to do these steps).
