I am new to controlling servos, so bear with me. I am controlling 8 servos via the controller. The controller is receiving serial input from my basic stamp 2. There are 6 hitek servos and 2 Futaba S3306 ‘hi torque’ servos. I can get the hiteks to work just fine, but no matter what command I issue to the futaba’s they always move only CW about 30 degrees. I can’t get them to move any other direction. I’ve triple-checked connections and all seems fine. The indicator on the controller is solid yellow, but flashes green when receiving the commands. Also - what code should I use to reset the controller? I use LOW 1; HIGH 1 … is that correct?? (pin 1 is connected to the reset pin on the controller)
An example of my test code - trying desperately to get the servo to do something: (Baudrate = 84)
ServoTest:
SEROUT 16, Baudrate, [“starting ServoTest…,”]
PAUSE 300
SEROUT ServoRCV,Baudrate,[255,5,128]
PAUSE 1000
SEROUT ServoRCV,Baudrate,[255,5,0]
PAUSE 1000
SEROUT ServoRCV,Baudrate,[255,5,254]
PAUSE 1000
PAUSE 1000
RETURN
The above code simply makes it jolt forward 4 times. Yes the jumper is on.
Any ideas??
Thanks,
Norm
