Hi
Can anyone recommend a good and reliable feed back potentiometer that will be used as a position sensor for closing the loop in an oversized servo using a gearhead motor ?
Hi
I would check out mouser or digikey. They have a pretty good selection. They list the dimensions of the pot. I am not sure how you plan to attach the pot to your gearbox/motor but it probably needs to fit some dimension that you didn’t list.
