I’d love to be building robots and learning C/C++ right about now, but sadly this is not the case. I can’t build any files using pololu’s avr libraries. Following the Library User’s Guide, I got to step 6 and immediately ran into problems. When I double click on the simple-test aps file and AVR Studio runs, the build window displays the following:
Loaded plugin STK500
Loaded plugin AVR GCC
Loaded partfile: C:\Program Files (x86)\Atmel\AVR Tools\PartDescriptionFiles
Error Code: -2147467259:
If I select Build > Build, as per instructions, I get the following in the build window:
Build started 11.9.2009 at 17:18:12
0 [main] sh 3188 sync_with_child: child 5860(0x14C) died before initialization with status code 0x0
92844 [main] sh 3188 sync_with_child: *** child state waiting for longjmp
/usr/bin/sh: fork: Resource temporarily unavailable
avr-gcc -mmcu=atmega328p -Wall -gdwarf-2 -std=gnu99 -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT test.o -MF dep/test.o.d -c …/test.c
…/test.c:23: fatal error: opening dependency file dep/test.o.d: No such file or directory
compilation terminated.
make: *** [test.o] Error 1
Build failed with 1 errors and 0 warnings…
I have no idea what the problem is, though I suspect it is something obvious and simple. Help would be appreciated.
