I’m using the micro serial servo controller.
I’m trying to understand what is meant by range and the difference between 8-bit and 7-bit positions.
After setting the range to 31, using command 2, the values 0 - 127 seem to correspond to angles of 0-180 on the servo.
Using the default (15), values 0-127 correspond to angles of 0-90.
My current best guess is that servo position (in degrees) = (range setting/31) * 1.40625*(value between 0 and 127)
(or some similar function that maps directly to pulse width instead of degrees)
