Hello, this is my first time using any microcontroller. I have a maestro 24 and I’m trying to get channel 0 to flash a morse code sequence. I need the output to be ON (+5v) OFF (0v) in controlled, delayed fashion to send morse code.
I’m not sure what the code ‘servo servo’ does, but hacking together from other example scripts it does the job of turning the servo channel fully on and off. Below I have a working example of flashing the letter ‘X’ in morse code with an LED attached to the (-) and (S) terminals of the 0 servo channel.
My questions are simple. 1) is this the best, most efficient way to send ‘digital’ signals through the servo channels? i.e. is ‘servo servo’ the best way? 2) Is there a flat out better way you can think of send basically a TTL signal through the servo channels to send morse code?
Thanks for any insight,
-Adam
# Simple script in POLOLU Controller to flash X in morse code (-..-) in a loop.
begin #START THE CODE
#Dash - BEGIN
1 1 8000 0 servo servo #LED ON
500 delay #ON LENGTH
0 0 0 0 servo servo #LED OFF
150 delay #OFF LENGTH
#Dash - END
#Dot - BEGIN
250 delay #ON LENGTH
#Dot - END
#Dot - BEGIN
#Dot - END
#Dash - BEGIN
#Dash - END
#END of message - BEGIN
1500 delay #OFF LENGTH
#END of message - END
repeat #REPEAT FROM THE START
Hello, Adam!
I am glad you were able to get this working. In the Channel Settings tab of the Maestro Control Center, be sure to configure Channel 0 as an “Output” instead of “Servo”; one of the effects of that is that the LED will be much brighter.
The code “servo servo” would simply call the “servo” command twice, so if you understand what the “servo” command does (i.e. what values it consumes from the stack and what it does with them) then it should be easy to understand what “servo servo” does. The “servo” command is documented in the Maestro User’s Guide in the chapter about the Maestro scripting language.
It looks like you are trying to set channel 1’s target to 1 occasionally. The number 1 is a not a valid value for a channel target and I don’t think you’re even using channel 1 so you can just replace those double servo commands with normal, single servo commands. You can also use subroutines in order to save program space and save typing. Here’s how I would have written your program:
begin
x message_end
repeat
sub morse_led_on
8000 0 servo
return
sub morse_led_off
4000 0 servo
return
sub dash
morse_led_on
500 delay
morse_led_off
150 delay
return
sub dot
morse_led_on
250 delay
morse_led_off
150 delay
return
sub message_end
1500 delay
return
sub x dash dot dot dash return
This should be much easier to maintain over time.
Thanks David! This is much more concise and useful. I’m understanding the coding language better too. I’ll keep working at it. I want to get to a point where I can send whole sentences to be converted into morse code. I’m thinking I’ll need to get some C# or .NET programming for that task.
-Adam
If there aren’t too many sentences you could just store them in your Maestro as different subroutines. The subroutines would look like this:
