I would like to know if it is safe to use these two together.
Dual MC33926 Motor Driver Carrier
pololu.com/catalog/product/1213
and
2x 29:1 Metal Gearmotor 37Dx52L mm
pololu.com/catalog/product/1103
The specifications of the motor say Stall current @ 12V: 5000 mA, and the Driver can handle up to 5000 mA for a few seconds.
I know that based on the specifications the driver can handle, but, they are to close.
Do you guys think it is a problem? Should I drive the motors at a lower tension, like 10V or so?
Thanks!
Cheers!
Hi.
It should be fine as long as you do not use them in an application where the motors stall a lot or you quickly transition from full-speed forward to full-speed reverse a lot. The MC33926 is a robust chip that should work fine with these motors.
- Ryan
Ryan, thank you for your reply.
My question now is, I’m going to use then in a balancing robot. So, multiple transitions from forward to reverse are a given. But, since the reverses in the motion are just to balance the robot, and not to run, break and reverse, I do not think it would be a problem.
But, I could be wrong, I have no experience with motor drivers and DC motors.
What do you think?
How hard you are on the system will depend on how well you control it. I think it should be okay.
- Ryan
