I have an application which will require driving up to 14 servos from a single signal. How many servos can be driven from a single Maestro channel?
Hi.
A Maestro output is a 5V microcontroller output that is current limited by a 220 Ohm resistor. How many servos you could control would depend on the leakage current of each servo input, the voltage thresholds of the servo inputs, and the resistance of your connections. I would expect 14 servos to be fine if there isn’t a significant resistance in your connections.
- Ryan
