I’m trying to use a digital output from a Maestro to power an array of LED lights. The lights use 14v, so I am using a relay to switch the higher voltage circuit.
The relay needs 3v minimum to switch, and when active it draws about 70mA. When the digital output channel is turned on, the voltage across the signal and ground pins is just under 5v, which would be fine to switch the relay, but when I connect the relay, this drops to 0.6v, which isn’t enough to trigger the relay.
I thought that maybe the power required was too great for the USB power supply alone, so I connected the Vin pin on the board to a regulated 6v supply. This did not improve the situation.
Is there something I’m missing here? Or is it simply not possible to power a relay from the maestro? Is the current demand too high for the signal line? If I can’t use a relay, are there any better ways of achieving the same thing?
Any advice or suggestions would be much appreciated!
Cheers,
Greg
