Current monitoring
Hi, I would like to select the right Pololu current sensor. This would be positioned between UK mains supply and a vacuum tube amplifier. The normal running current will be around 350mA at 240Vac 50Hz. However, on initial initial power up there will a current inrush. This could theoretically go as high as 60A, although I will be including an inrush bypass using a relay and thermistors to limit this to a fraction of this. The inrush lasts no longer than 50 or so milliseconds and will be limited. Can you please offer some guidance on what is the best Pololu option for monitoring input current. I would like to be able to measure the current as a dc voltage / using an oscilloscope. Although I am familiar with using Arduino. Many thanks, Andy
I think The Pololu ACS724 family is actually a good fit because it provides an analog output and galvanic isolation between the current path and the sensor electronics.
Hello, Andy.
You can find our selection of current sensors here. Working with such high voltages is very dangerous, so it’s not the kind of thing we would advise you on. We recommend working with someone who is qualified to assess the suitability for your application using the available documentation.
Hi thank you both for your replies. I will investigate further and decide how to proceed. Again many thanks.
Andy
