Hi,recently bought my second pololu micro servo controller.when I first connected it to my pc the control center wont detect it.my other pololu is being detected but not this one.
Hello, Kalvik.
I’m assuming you are using Windows. What version of Windows are you using? What entries do you see for the Maestro in your computer’s Device Manager when you plug in the one that isn’t working and leave the other one unplugged? It should look something like this if your drivers are installed properly:
problem solved thanks my drivers were not installed properly.
I’m glad you were able to solve your problem. Do you have any idea why the drivers were not installed properly the first time? Maybe you forgot to unplug the Maestro after running the installer? Did you see any error messages during the installation process?
