I just recently bought a couple Pololu Dual Serial Motor Controller’s and also the Pololu Deluxe Serial Adapter. I am hoping to bypass the need for a microcontroller by having the motor controllers controlled directly by the pc.
I set it all up for a test run and couldn’t get the computer to turn on the motor. Here are the steps I took:
- Plugged in Serial Adapter to computer, and connected pins 6 and 7 (DSR & RTS)
- Linked GND pin from serial adapter to negative of power supply to 1st pin on motor controller/
- connected positive to power supply.
(Here’s where i think i am incorrect)
4. Connected reset line through a 4.7kohm resistor to positive of same power supply.
connected pin 3 (TX) of serial adapter to pin 4 (serial control input) of motor controller
connected motors
How far off am I?
