It looks like your code uses the goto
function to immediately start running your main_loop
code, which repeatedly sets the positions of servos 1 and 2 without a delay and does not exit. So, your code is basically just running:
begin
4460 1 servo
7616 1 servo
7000 2 servo
2000 2 servo
repeat
I recommend using the “Step Script” button to step through your code to see what is happening and when. You can watch values get added and removed from the stack and a cursor helps you identify which part of your code is being executed.
Also, it looks like you are not using channel 3 in your code, which you mentioned you were using to control your LEDs. So, unless you incorporate that into your code, you should not expect to have control of your LEDs.
Additionally, to expand on what Amanda mentioned earlier, setting a value of 20,000 is also not that meaningful, since it basically gets truncated.
-Jon
