Changing Motor
How can i change the motors of RP5 Tracked Chassis ?
It is possible to change the RP5 motors, but it is not easy to do. Here are some (not particularly promising) posts about changing RP5 motors:
You will need to find motors that can run at 7-9V, have a 2mm shaft diameter, and can be mounted inside the motor compartment.
- Ryan
