I’m trying to move my VS-19 Pico Linear Servo with 6 channels Maestro, but it doesn’t move to the maximum position. Datasheet of the servo says “This linear actuator accepts a servo pulse from 800- 2200 microseconds(μS) with a neutral potision of 1500μS”.
I see the range of pulse from only 992-2000 on Pololu Maestro Control Center.
Now We get to know why it is stuck.
How can I edit the range of pulse? I need to move it correctly.
992 and 2000 are the default Min and Max pulse width settings within the Maestro Control Center, respectively. You can edit those values under the “Channel Settings” tab of the Maestro Control Center. In particular, you can click within the Min and Max fields and enter a new value for the pulse-width you want, or you can click the up and down arrow buttons to increment and decrement the current value. Once you have entered a value you want, be sure to click the “Apply Settings” button at the bottom right corner of the Maestro Control Center.
