Can I command several Pololu Servo Controllers from PC?
Can I command several Pololu Servo Controllers from PC over the USB? 24 channels is simply not enought. I suppose this should not be a problem, there just would be more virtual COM ports, but I want to double-check before I order them. Thanks for answer.
It sounds like you are talking about one of our Maestro USB Servo Controllers. If so, yes, you can control multiple Maestros from multiple USB ports on a PC.
-Derrill
