I have a micro maestro 6 channel USB servo controllers. Well i actually have 2 of those.
And i have 2 servos.
I wanted to make a button board looking something like this:
But as im already using 2 servos, then i only have 4 channels left for buttons.
and i need a minimum 5 buttons.
So as I was googling for hours I realized i could possibly make a button board, attach to micro controller, attach micro controller to the 6 channel maestro controller and i would be able to have 5 buttons.?
Im just a beginner here to bear with me.
Mabye i could use my other 6 channel maestro, attach buttons to that and connect that to the other maestro which has the motors attached to it and i could control the motors (connected to maestro board nr.1) using the button board connected to button board 2 ?
and this here image from the boards user manual
uhm. since im having at least 5 buttons would i just put the resistor at the back of the board? and connect them? i probably will end up doing so. but my original question is the main thing.
attaching buttons to board nr.2 attaching board nr2 to board nr.1 and attaching board nr1 to servos.
and of course making board number 2 make the channels be input thingy.
And as of my drawing. is not right that i connect all of the buttons ground together?
basically i have momentary push buttons and i want that you push one. and the motor makes its move. i push another and the motor stops doing the movie button 1 says and starts doing the button 2 move.
So i would press button 1 and it would hold. and then stop once i press button 2.
(no i dont want an on/off switch instead i dont like it.)
As you can see im a complete newbie but i just want to finish this project for once.
Any help is so greatly appreciated.
