I’m using the Control Center with a Micro Maestro and have been successful getting it to do what I need but I have some questions that I hope someone can help with. I’ve worked through the manual (which is OK) but I think I’m missing a few things and I can’t seem to get the answers from the manual.
What is the general definition for a “frame”? I know it defines a step in a sequence but I’m struggling a bit with what it actually is. It seems frames can contain a set of channel settings or a complete script.
When working with sequences, why do I only get a list of frames vs. a symbolic description of what the frame actually is? I know I can provide a name but it seems more info about the frame should be provided without me having define everything specifically. I know I can select a specific frame within the sequence and load it, which populates the channel settings or script definition but there appears to be no way to know what a frame is without doing this. Am I missing something?
When creating a script is there a way to save what is entered in the editor to the local PC? I can’t find any indication of a SAVE SCRIPT button anywhere. This seems really odd.
When you save a settings file, what is actually saved?
Appreciate any help.
