You can use any pins you want. Note that the example you’re using as a reference is for the Orangutan SVP, which handles servos slightly differently than your Baby Orangutan since it has dedicated servo outputs connected to a demultiplexer. You would want something like:
const unsigned char servoPins[] = {IO_D0, IO_D1, IO_D2};
servos_init(servoPins, 3);
Right now the only example programs included with the Pololu AVR library are for the Orangutan SVP, but the next release of the library will include the following two general servo examples that work the same way on all Orangutans (the comments should explain how to use it and why it uses the “B” versions of the servo functions):
#include <pololu/orangutan.h>
* servos1: for all Orangutans (LV, SV, SVP, X2, Baby) and the 3pi robot.
* This example uses the OrangutanServos functions to control two servos
* connected to pins PD0 and PD1. The servo pulses are generated in the
* background using interrupts, so program execution is not blocked by
* the pulse-generation code. If you are using the Orangutan SV or SVP,
* you can power the servos directly from the board's 5V bus. For all
* other Orangutans (LV, X2, Baby) and the 3pi robot, you need to power
* the servos from a separate source since the on-board voltage regulators
* do not have enough power to drive typical servos. This example uses
* pushbutton inputs to trigger events, so you will need connect an external
* pushbutton (or wire) to the correct pin if if you are using a Baby
* Orangutan.
* The program will hold the two servos connected to pins PD0 and PD1 at
* default positions unless a user pushbutton is pressed. While the button
* is held down, the servos will slowly move to new positions. When the
* button is released, the servos will quickly go back to their default
* positions.
* Note: the "B" version of the servo functions are used in this example
* so that it behaves the same for the Orangutan SVP as for all other
* Orangutans. If you are not using the Orangutan SVP, you can do not
* need to use the B versions of the functions (e.g. you can use
* set_servo_target(0, 1300) instead of set_servo_target_b(0, 1300)).
* If you do this, you should replace the call to servos_init_extended()
* with servos_init().
* The OrangutanServo library uses timer 1, so it conflicts with the
* OrangutanBuzzer and OrangutanPulseIn libraries, which also use timer 1.
* You should not add calls to OrangutanBuzzer or OrangutanPulseIn
* functions to this example.
* https://www.pololu.com/docs/0J20
* https://forum.pololu.com
int main()
// This array specifies the correspondence between I/O pins and
// software-PWMed servos. Servo 0 is on pin D0 and servo 1 is on pin D1.
const unsigned char servoPinsB[] = {IO_D0, IO_D1};
servos_init_extended((unsigned char[]){}, 0, servoPinsB, sizeof(servoPinsB));
while (1)
set_servo_speed_b(0, 0); // no speed limit (move as fast as possible)
set_servo_target_b(0, 1200);
set_servo_speed_b(1, 0);
set_servo_target_b(1, 1700);
// wait for any button to be pressed
unsigned char button = wait_for_button_press(ANY_BUTTON);
// set speed of servo 0 to 150, which means that the pulse width
// will change by at most 15 microseconds every 20 ms, so it will
// take 800 ms (0.8 s) to go from a position of 1200 to 1800.
set_servo_speed_b(0, 150);
set_servo_target_b(0, 1800); // start servo 0 moving
// set speed of servo 0 to 60, which means that the pulse width
// will change by at most 6 microseconds every 20 ms, so it will
// take 1333 ms (1.3 s) to go from a position of 1300 to 1700.
set_servo_speed_b(1, 60);
set_servo_target_b(1, 1300); // start servo 1 moving
// wait for pressed button to be released (servos will keep moving)
wait_for_button_release(button);
// when button is released, we jump to the top of the loop and the
// servos positions are reset
#include <stdio.h> // required for printf()
* servos-and-buzzer: for for the Orangutan LV, SV, SVP, X2, Baby-O and 3pi robot.
* This example demonstrates how you can have a program that makes sounds
* and uses the OrangutanServos library. OrangutanServos and OrangutanBuzzer
* both use the same hardware timer (timer 1) to operate, so the two
* libraries are not compatible with each other. However, they can be
* alternately used to make sound, then control servos, then make sounds
* again. This program also defines a simple note-playing function
* (play_simple_note()) that uses loop delays to generate a signal with
* the appropriate frequency on the buzzer pin. This is a blocking function,
* but it does not use timer 1 and does not require the OrangutanBuzzer
* library (other than some #defines from the header file), so it can be
* used to play notes while servos are active.
* Orangutan.
* set_servo_target(0, 1200) instead of set_servo_target_b(0, 1200)).
#include <avr/pgmspace.h> // this lets us refer to data in program space (i.e. flash)
// store this fugue in program space using the PROGMEM macro.
// Later we will play it directly from program space, bypassing the need to load it
// all into RAM first.
const char fugue[] PROGMEM =
"! O5 L16 agafaea dac+adaea fa<aa<bac#a dac#adaea f"
"O6 dcd<b-d<ad<g d<f+d<gd<ad<b- d<dd<ed<f+d<g d<f+d<gd<ad"
"L8 MS <b-d<b-d MLe-<ge-<g MSc<ac<a ML d<fd<f O5 MS b-gb-g"
"ML >c#e>c#e MS afaf ML gc#gc# MS fdfd ML e<b-e<b-"
"O6 L16ragafaea dac#adaea fa<aa<bac#a dac#adaea faeadaca"
"<b-acadg<b-g egdgcg<b-g <ag<b-gcf<af dfcf<b-f<af"
"<gf<af<b-e<ge c#e<b-e<ae<ge <fe<ge<ad<fd"
"O5 e>ee>ef>df>d b->c#b->c#a>df>d e>ee>ef>df>d"
"e>d>c#>db>d>c#b >c#agaegfe f O6 dc#dfdc#<b c#4";
#ifndef _ORANGUTAN_X2 // this code isn't needed if we're using the Orangutan X2
// frequencies in tenths of a Hertz of lowest 12 allowed notes (stored in program memory)
unsigned int base_freqs[] PROGMEM = {412, 437, 463, 490, 519, 550, 583, 617, 654, 693, 734, 778};
// returns the frequency (in Hz) for the specified note. Note macros are
// defined in OrangutanBuzzer.h. For example to get the frequency of note
// C sharp in octave 5:
// get_frequency(C_SHARP(5));
unsigned int get_frequency(unsigned char note)
unsigned int freq = 0;
unsigned char offset_note = note - 16;
if (note <= 16)
offset_note = 0;
else if (offset_note > 95)
offset_note = 95;
unsigned char exponent = offset_note / 12;
// read the base frequency for the requested note from program memory
freq = pgm_read_word(base_freqs + (offset_note % 12));
// in the following calculations we add half of the denominator to the
// numerator to get a result that is rounded properly (otherwise, the
// decimal is just truncated and something like 3.9 becomes 3).
if (exponent < 7)
freq = ((freq<<exponent) + 5) / 10; // == (frequency * 2^exponent) / 10
else
freq = (freq*64 + 2) / 5; // == freq * 2^7 / 10 without int overflow
return freq;
#endif
// Play a note without using timer 1 or the OrangutanBuzzer library, which
// means it is safe to use this function while using the OrangutanServo or
// OrangutanPulseIn libraries.
// This is a blocking function; execution does not return until note is done.
// This function will not have an effect if timer 1 is configured for
// buzzer operation. The argument freq is in Hz and duration is in ms.
void play_simple_note(unsigned char note, unsigned int duration)
#ifdef _ORANGUTAN_X2 // buzzer is controlled by aux MCU on X2
x2_play_note(note, duration);
delay_ms(duration);
#else // if using any non-X2 Orangutan or 3pi robot
unsigned long time = get_ms();
unsigned int freq = get_frequency(note);
unsigned int half_us_delay = (500000UL + freq/2) / freq;
while (get_ms() - time <= duration)
// BUZZER_IO is buzzer pin (defined in OrangutanBuzzer.h)
// use loop delays to generate a square wave on buzzer pin at
// the appropriate frequency for the note we want to play
set_digital_output(BUZZER_IO, HIGH);
delay_us(half_us_delay);
set_digital_output(BUZZER_IO, LOW);
#endif
int main()
play_from_program_space(fugue);
clear();
lcd_init_printf(); // required for using printf()
printf("Fugue");
delay_ms(200);
printf(".");
delay_ms(200);
printf(".");
delay_ms(200);
printf(".");
delay_ms(500);
while (1)
clear();
printf("Press a\nbutton");
// setup pins D0 and D1 as servo outputs and initialize timer 1 for servo pulses
servos_start_extended(0, 0, (unsigned char[]) {IO_D0, IO_D1}, 2);
// move servos at full speed to their initial positions
set_servo_target_b(1, 1200);
delay_ms(50); // let positions be updated before we change the speed
// set servo speed to something slower
set_servo_speed_b(0, 200);
set_servo_speed_b(1, 100);
while (1)
// blocking sound functions that works while servos are active
play_simple_note(C(5), 50);
play_simple_note(E(4), 50);
delay_ms(400);
if (button_is_pressed(ANY_BUTTON))
wait_for_button_release(button_is_pressed(ANY_BUTTON));
servos_stop();
break;
delay_ms(200);
set_servo_target_b(1, 1800);
delay_ms(400);
// disable servo signals (allow OrangutanBuzzer code to be used again)
servos_stop();
break;
// since we have called servos_stop(), we can use OrangutanBuzzer code again
play("cdefgab>c");
delay(1000);
- Ben
