I have succesfully connected my servo (HS785HB) to the micro maestro and if I test it with my PC everything is okay.
But if I now try to connect the maestro the the Arduino I can not get the servo moving.
I have connected the 5V and GND from the Arduino to the maestro. Power for the servo comes from a battery.
Pin 7 of the arduino is used to perform a reset of the maestro.
The device ID is set to 0 by the PC software.
The yellow LED flashes 2 times each second.
I use the following code on my Arduino:
#include <SoftwareSerial.h>
#define txPin 4
#define rxPin 3
SoftwareSerial mySerial(rxPin, txPin);
void setup()// run once, when the sketch starts
pinMode(7,OUTPUT);
pinMode(7,HIGH);
delay(50);
pinMode(7,LOW);
mySerial.begin(9600);
delay(1000);
void loop()
delay(1000);
set_target(0, 8000);
delay(1000);
set_target(0, 4000);
void set_target(unsigned char servo, unsigned int target)
mySerial.write(0xAA); //start byte
mySerial.write((byte)0x00); //device id
mySerial.write(0x84); //command number
mySerial.write(servo); //servo number
mySerial.write(target & 0x7F);
mySerial.write((target >> 7) & 0x7F);
Is there anything wrong in my code or whats going on?
It looks like you are leaving pin 7 low, which is connected to the Maestro’s reset line, so that would prevent the Maestro from running. You said the LED was blinking twice per second though, which would mean the Maestro was running, so I’m not sure what is happening. Please try bringing the reset line high some time before the end of your setup() function.
Also, this shouldn’t cause the problem, but your serial bytes are not quite right. Please try replacing those lines with this:
mySerial.write(12); //device id (assuming it is still at the default value)
mySerial.write(0x04); //command number with MSB cleared
In the PC tool I have set a minimum of 688 and a maximum of 2496.
How can I convert these values to drive the servo with the pololu protocol? What values do I have to set?
Thanks.
Stefan
edit: okay i did check it with the pc tool. everything is okay now. i only have to multiply the value by 4.
