Great! I am glad you figured out the issue and fixed it; thanks for letting us know.
By the way, I see from the other post you made here that you decided to use a second button to stop your script. However, if you only want your Maestro script to run through your sequence once, you could alternatively replace REPEAT with QUIT, which would stop the script. For more information about the QUIT command, see the “Command Reference” section in the Maestro’s user’s guide.
