Arduino and A4988 Stepper Motor Problem – Help!
Hey, I’m a student playing around with Arduino and still learning things step by step :sweat_smile:. Recently, I tried using a Pololu A4988 stepper motor driver in one of my projects, but honestly, I don’t really know much about Pololu stuff yet. This is my first time using one, so I’m still figuring out how it all works together.
I’m making a small Arduino-based stepper motor project just to learn. The plan is to control the motor’s speed and direction using Arduino and the A4988 driver. It’s a simple little automation/robotics thing, like moving something to a specific position.
Here’s the problem: my motor doesn’t behave like I expect :sweat_smile:. Sometimes it stalls, sometimes it jitters, and other times the driver just seems to shut down or stop working. I’ve double-checked my wiring and Arfuino code, but I’m not sure if I’m setting the current right or missing some driver setting.
For example, when I run my sketch, the motor might move a few steps and then stall, or sometimes it just vibrates without turning :confused: . I also noticed the driver’s LED goes off for a moment, like it’s shutting down. I’ve checked everything I can think of, but I’m still stuck maybe it’s the current limit, microstepping pins, or something else.
I can share my Arduino code and wiring diagram too if that helps. Any tips or guidance would be super appreciated! Thanks a ton in advance! :pray:
I’ve seen some problems related to mine here but not sure if it will work
I moved your post to the “Motor controllers/drivers and motors” support section of the forum since it seemed more appropriate.
Could you post more details about your setup, such as what stepper motor you are using, how everything is powered, and what you set the A4988 carrier’s VREF voltage to? Our A4988 carrier does not have any LEDs on it; could you clarify what LED you are referring to? Also, could you post some pictures of your setup that show all of your connections, as well as the simplest but complete Arduino sketch that demonstrates the problem?
Hi, thanks for moving my post. I’m using an Arduino Uno with a Pololu A4988 carrier and a bipolar NEMA 17 stepper motor. I don’t have the exact mofor current rating with me right now, but I can check it and share it if needed.
The motor (VMOT) is powered using an external DC power supply, while the Arduino is powered through USB, and the grounds are connected together.
I haven’t measured it with a multimeter yet. I adjusted the potentiometer slightly just to get the motor moving, but I realize now that not setting VREF properly could be causing the issue. I can measure it and report back with the exact value.
Thanks for pointing that out. You’re right that the A4988 carrier itself doesn’t have an LED. The LED I noticed turning off is actually on my external power source/module, not on the A4988 board. Sorry for the confusion there.
I’ll upload clear photos of my wiring and connections, and I’ll also share the simplest complete Arduino sketch. I’m using that shows the problem (basic STEP/DIR control). Thanks a lot for your help.
