My project will consist of using 6 servos for an angel wing project. Six Hitec HS 805BB will be used. Servos 1&2 will control the raising of the right wing. They will be y connected and plugged into the maestro. Servos 3&4 will control the raising of the left wing. They will also be y connected. Servos 5&6 will control the flapping of the wings; also y connected. I will be using two relay switches that will run through the costume and into my palm for ease of use. I am extremely new at this and have tried to do as much research as possible along with talking to Pololu techs prior to making any purchases. My questions/confusion is:
*I understand that a resistor is needed for the 6 channel per the instructions, however, I’m unsure of where to solder on the pin if the relay switch has 3 female head to fit channel one. I have seen the photo description, but I’m confused of how to connect it all together. I want the first relay switch to be placed on channel one and once activated, will start servos 1-4. I want a second relay switch to be on channel 4 to activate servos 5&6. Is it even possible to use two different relay switches and does it include a second resistor?
*will there be a specific command I will have to create myself for the switch or can that be generated by the program once I’ve set my sequences?
I appreciate any feedback!
