I’d like to setup the MMA7260QT 3-Axis Accelerometer (Pololu Part 766) in a car computer project I’m working on. The accelerometer board will be powered by 5V to the VIN pin. The sensitivity of the accelerometer can be adjusted from 1.5g to 6g through the use of two jumpers. I’m confused however about the following language:
“The sensitivity selection pins GS1 and GS2 are pulled up to the Vcc line, making the default sensitivity 6g; these pins can be pulled low by a microcontroller or through jumpers. For 5 V microcontroller applications, the lines should not be driven high. Instead, the microcontroller I/O pin can emulate an open-drain or open-collector output by alternating between low output and high-impedance (input) states. Put another way, if you are using a 5 V microcontroller, you should make your sensitivity selection I/O lines inputs and rely upon the internal pull-ups on the GS1 and GS2 lines if you want them to be high. It is always safe for you to drive these lines low.”
Since I’m powering with 5V to the VIN pin and not 3.3 to the “3.3V/Vcc” pin, does this mean I should or should not use the jumpers (which limits my adjustability) or does it not matter.
Please forgive a newbie to this.
Thanks, Steve
