So I know you are not meant to unplug a stepper motor whilst the driver is powered. However I am wishing to swap between motors without killing the power to the machine.
Is it possible to send a low signal to the sleep pin which should turn off the fet outputs perform the change and then un-sleep or enable the driver. Would this be safe?
Or is there another solution?
